Problem with height in RTH mode
814 8 2016-12-25
Jmichel33
When i activate a RTH, my drone (Phantom 4 Pro+) doesn't respect the height that i'd progam (35 meters) and flight till 120 meters once, and 63 meters during another flight. !!!
I think it's not normal !
I saw other people met the same problem
Any solution ?
2016-12-25
Steve-76
Flight distance : 175495 ft
my p3s works fine.. now 1 are you already flying at those higher altitudes because it won't lower itself if it's below are th it will raise if it's above rth it will stay the same height and come back. I have no experience with the Phantom 4 or 4 plus but with all the optical sensors was there anything near it that might have caused it to raise on its own
2016-12-25
DJI Natalia
Flight distance : 318 ft
This case has been reported and it will be fixed with the next firmware version, sorry for the inconvenience caused.
2016-12-26
Jmichel33
DJI Natalia Posted at 2016-12-26 13:19
Is it "hard" or "soft" problem ?
2016-12-28
Jmichel33
Steve-76 Posted at 2016-12-25 18:23
NO ! The aircraft flies at around 50 meters !!
2016-12-28
Geebax
Steve-76 Posted at 2016-12-26 04:23
Please note that the OP posted in the Phantom 4 Pro section of the forum. The issue he is reporting is a known fault and has been reported before.
2016-12-28
f3honda4me
To avoid this, set an RTH height that is HIGHER than you plan to fly at.
2016-12-28
DJI Natalia
Jmichel33 Posted at 2016-12-28 13:44
It will be fixed with the firmware (Soft).
2016-12-29
theGrindLab.com
Flight distance : 1375846 ft
Steve-76 Posted at 2016-12-25 09:23
Nah. It's a commonly-reported issues with this model.
2016-12-29
