kevinelliott
Flight distance : 354131 ft
In your subject for this post you ask which card you should buy. Let me help you out with that.
First of all, the Mavic supports microSD cards that adhere to the UHS-I bus. It is highly suggested that you choose a minimum of Class 10 if you are going to be doing any 2.7K/4K recording. The Speed Rating of Class 10 is the top standard speed rating, and ensures that at least 1080P can be recorded. Ideally you want U1 or U3, which is a UHS Speed Rating. U1 is essentially comparable to Class 10, but on a UHS-I bus (rather than the previous bus). U3 is a significant boost to read/write. And cards with support for the UHS-II bus are insanely fast, but these cards are more rare and very expensive.
Note that getting a UHS-I U3 or UHS-I U1/U3 card is unnecessary with the Mavic. It will *not* make use of the additional speed at all. The recording will not be any more superior, nor will it ever take advantage of it.
The one time you will benefit from the highest speed cards is when you are copying your recording to your computer, which can take advantage of the read speed to grab your video faster. If that is truly important to you, then invest a few more bucks in your cards.
You can learn more about SD card speed ratings and buses here.
https://www.sdcard.org/developers/overview/speed_class/
I put together a site called PriceHunter (pricehunter.co) that lets you compare prices of microSD cards so you can be sure you're getting the best price. It updates from Amazon and Newegg multiple times a day. Email alerts are coming soon. Right now the cheapest and best value (and the one I use with my Mavic) is the Lexar 64GB UHS-I U1. It's more than suitable for 4K recording, but it has write/read speeds that exceed the minimum requirements of the U1 UHS Speed Rating specification too. The main point of the site is to know when the cards are worth buying, be alerted when it goes cheaper, and also to buy the card that is cheaper per gigabyte than others. Hope it's helpful  |
