Donnie Stugots
Flight distance : 3636782 ft
Oh , yea , big time shake, does the camera stay steady on the ground ? be sure to test this , it will help diagnose a mechanical problem vs something else . Looks to me like the gimbal is not mounted correctly , inspect all of the dampers and replace if necessary . Is this with an X3 or X5 camera ? be sure to look at the video feed with the Motors off and see if it shakes like that , then we know if it is something in the connectors etc vs vibration. I am going with vibration on this one , though Mark says he has experienced this with bad pin connections so let us know what you find .
where are you locaed at , I cant quite pin it down from the video ? Guessing CA ?
donnie
