Angelo26
Flight distance : 799718 ft
Austria
Dear Zolima, fellow Austrian !
Also our beautiful drone sticks to the quite simple physics of aerodynamics. As with cars (!! !!) there will always be a difference between "factory values" (achievable at optimum aerodynamic conditions) and real life.
Maybe 27 minutes real flight time can be achieved at sea-level, zero-wind-conditions, switch on and immediate take-off, short climb to final flight altitude at approx. 30m and then slow (approx. 10km/h) level-flight only forward, no moving of the gimbal and RTH without any timely/battery-capacity safety-margin. ( I dunno how much battery is consumed when continous recording at 2,7k or 4k).
Active flying (permanent ascending, descending, pitch, yaw, accelerating, breaking) in thinner air (higher rotor-rpm needed = higher electric consumption for both active flying and thinner air) at higher speeds (a drone is extremely energy-inefficient like helicopters or gyroplanes both by design = non-aerodynamic body-shape with high air-resistence and aerodynamics = overall air-resistence increases NOT linear but by the SQUARE of forward velocity both from the drone´s body AND the rotors) increases battery-consumption SIGNIFICANTLY. PLUS: DJI integrated - very wisely ( ) a very "conservative" estimate of CALCULATED remaining flight time (comparable to the legal obligation of every pilot to calculate fuel consumption PRIOR to any flight regarding maximum range and flight-time PLUS an extra reserve for at least 30 minutes flight-time to prevent "controlled flight into terrain").
Would a larger battery solve the problem ? Not really: Mavic PRO by it´s overall take-off-weight seems to have the optimum weight-endurance-balance in it´s class of size. Every added weight to batteries for longer flight-endurance might result in ineffectiveness, meaning, for every added 100 grams of batt-weight maybe only 30 seconds additional flight-time might be the result (although I didn´t make any math-calcs this is just a VERY coarse and unscientific GUESS ! )
So just be happy with the performance as it is, You won´t find better NOW (coming from a clumsy Parrot AR 2.0-drone with 10 minutes endurance and sh.. camera I know what I am speaking of) and hope for advances in battery-technology in the next ten years when weight-to-energy-density can compete or supercede combustion-engines. Maybe then in ten years or so DJI will issue a drone (Mavic Pro 5.0) with 6 h endurance ................. |
