bbrunner11.gmai
it uses the wifi signal to transmit your phone's GPS coordinates every couple of seconds. If you lose control connection but still have wifi, then it will come back to wherever your phone is... so it's pretty obvious that if you are moving at a speed greater than the quad can fly, you will eventually lose wifi connection and your bird will return to wherever the last recorded home point was... some point between where the bird is and where you are. as long as there is a wifi connection it will transmit the home point, so if you travel out of range you will need to turn around and re-establish the wifi connection or it will just land. however, chances are you will lose the wifi signal way before losing the control connection, so it's almost a moot point.
edit: also of note, if your cell phone has a crap gps connection, then DHP can be anywhere in the circle, so make sure of your phone's GPS connection before even attempting this (ie, in google maps, it should be a tiny dot, not a blue circle around a tiny dot)
