Landing issue after update
754 12 2016-12-26
Nick823
Flight distance : 4911 ft
Has anyone had this issue?   I just did a firmware update with a little trouble but finally got it done after several attempts on my computer.  After the upgrade it seems the mavic will land but a little erradic.  Manual or auto land it will hover like normal and once it tries to land it will shoot back up six inches or so then drop land.  It doesn't seem to land smoothly like it did b4 the upload.   Any suggestions.
2016-12-26
Nick823
Could it be that a setting got changed after update?
2016-12-27
Hi Nick, please try to do a VPS calibration and a cold IMU calibration.
Then test it again. Please keep us posted.
2016-12-27
Nick823
DJI Mindy Posted at 2016-12-27 19:16
Did the IMU, but the VPS calibration keeps telling me to reboot Aircraft.  Any suggestions.
2016-12-27
Nick823
I noticed a couple of bad spots on two of the blades.  Would yhat cause an issue.  Its not hovering like it did and moves quite a bit
2016-12-27
Nick823 Posted at 2016-12-27 21:35
Did you install the latest version of the DJI assistant?
Please try to reinstall it and do the VPS calibration again.
As for the bad spots, could you please take a photo of that?
2016-12-27
Nick823
DJI Mindy Posted at 2016-12-28 15:20
I had just downloaded the Assistant, unless it has changed in the last couple of days, should be the latest.  Ordered new blades so I can try again.  There are a couple of chips out of two of the blades.  Will try to get pic.  Also when I tried to do the VPS calibration I kept getting a magnetic error on controller and plus the assistant kept asking me to reboot aircraft.
2016-12-28
Nick823 Posted at 2016-12-29 04:41
Could you please find the log file by below path?
C:\User\AppData\Roaming\DJI Assistant 2
2016-12-28
Nick823
Not sure how to find log file.  Does mavic need connected to pc
2016-12-29
Nick823
Log files saved.  What do you use to open once saved on laptop
2016-12-29
pierce
Portugal
I experience that same issue. I receive the mavic yesterday do all the updates and calibrations. I'll try do downgrade and see what happens.
2016-12-29
pierce
Portugal
pierce Posted at 2016-12-29 14:51
I also cant calibrate the joystick.
Tried with android and ios...
2016-12-29
Nick823
I reinstalled assistant, will try VPS calibration soon as I have time.
2016-12-29
