so I went hiking in Hawaii and came to a water fall. the area was small and I could not get a gps lock. so I just flew the drone. no big deal. so I flew towards the water fall and then wanted to follow it up to the top. once I hit 16 ft I could not go any higher. Max altitude reached. how do you change that?
Hello, the max altitude in opti mode is 5m, in atti mode is 30m.
If you need to go higher, you could try to disable downward vision positioning. But please be more careful.
DJI Mindy Posted at 2016-12-27 20:31
so how do you disable opti mode and go in atti mode?
