Dropped My TX
1147 3 2015-2-13
gwhiz2k
Hi
I dropped my TX... Stupid I know. I'm not flying the Inspire yet (too cold), but I've been testing gimbal/camera and flying the simulator with the bird inside.
It basically dropped about 3.5 feet, onto my kid's plastic toy, which was on a soft carpet. It looks ok, no damage that I can see..
My Question:
a) Does anything need to be calibrated after a jolt to the Tx?
b) Can I verify it's working ok using only the simulator?
c) Are there any settings in the app to check if everything's ok?
Thanks
2015-2-13
T J Gilbert
Flight distance : 74659 ft
Tx are pretty tough.
If you did not break any switches or antennas, I'd think you're okay.
Is there anything obviously not working?
I once dropped my new JR9303 from about 2' and snapped off two switches.
It happens...
2015-2-13
Dave E
Flight distance : 729560 ft
Personally I would send it for testing to dji considering the safety issues and potential cost implications if it is damaged. Failing that I would calibrate your Tx anyway. Then test it using the simulator. If that works ok, get a friend to help you range test the Tx with your inspire with the props off. I hope it is all ok.
2015-2-13
dbeck.promobox
Where is the program for the Inspire TX?  It can't be the same foe the Phantom?
2015-2-15
