Fix for connecting DJI GO Android app to Phantom 3 Standard
10144 12 2016-12-28
peaking
Hey guys, I had lots of problems connecting my Nexus 6P on Android 7.11 to the P3S via the app. The only fix that worked was here:
http://forum.dji.com/forum.php?m ... &fromuid=529997
but that was a really old thread and I belive this problem is more specific to Android and the way it handles wifi connections with no internet connection
Big thanks to user ro.othorick:
http://forum.dji.com/home.php?mo ... uuid=81b7ad7c74ded8
And here is a quick video i made with this work around:
hope this saves some of you somtime and the guys at DJI can fix this prolem
2016-12-28
JACKODOG-ANDROI
Flight distance : 208383 ft
Good Video Thanks!
2016-12-28
MerlinL14
Flight distance : 2858 ft
What a great, informative video. I never had the connection problem because I was using a 7" Tablet from the get go, so could never understand why so many issues with connecting. DJI, time to rewrite some of the instructions I think.
2016-12-28
solentlife
Flight distance : 1087530 ft
Russia
Just a question .... on my androids incl. 6.0 - I can disable 4g, 3g, individual modes, connections, to only use what I need. Can you not do this on your 7 machine?
If I enable Airplane mode on any of my gear - it disables all comms systems including wifi ..... so I would never get any connection with my P3S ......
Interesting.
Nigel
2016-12-28
peaking
solentlife Posted at 2016-12-29 14:04
I usually do this how i showed on the video. I can engage airplane mode but can then go in and select wifi and/or bluetooth be on even though airplane mode is engaged. I have always done it this way even when I had an iPhone
2016-12-28
solentlife
Russia
Well I just learnt something ... just did it on the tablet I'm using now ....
Never knew before ... and I've been with android etc. from day one !
Nigel
2016-12-28
Big Poppa 45
Flight distance : 7799 ft
peaking Posted at 2016-12-28 19:57
Wow, school is in session.   I did not know that, and tried it one of my tablets and my phone...
Thanks,
Big Poppa 45
2017-1-1
probonic
Flight distance : 61211 ft
It looks like this is probably an issue with Android 7 (Nougat).  I have a Samsung Galaxy S7 Edge which works fine, and that is Android 6.  I believe Nougat is being released soon for the S7, so it'll be interesting to see if I suddenly have to do this.
To my mind it shouldn't be an issue if it was doing what I thought it would logically do - when you connect to the Phantom via WiFi, the RC, the aircraft and the camera are on local IP addresses (192.168.1, .2 and .3).  Android *should* only be trying to use the mobile connection for access to anything *outside* the local network (i.e. the Internet), so if it was doing what it was supposed to do the connection to the Phantom should work, with the added bonus that streaming would actually work in Android, as it does currently when using iOS.  Android, at least at the moment, does not allow data connections to both WiFi and mobile at the same time as iOS does.
Hopefully it's a good sign and maybe through DJI and/or Android updates this procedure will no longer be required and streaming will also finally work in Android.
2017-1-3
peaking
probonic Posted at 2017-1-3 10:04
I think you're right mate....I've been living in a NEXUS world for years now and have become accustomed to having the latest Android OS loaded...I have failed to realise most Android devices are still on 5 or 6 and as they move up to 7 this will become a problem...unless DJI issue a fix this will be an interesting issue to watch unfold
2017-1-4
DeeJayEye
Is it DJI's issue or Googles (Android)????
2017-4-1
fansc9996e1f
Bahamas
I have a note5 an it not connect
2017-12-16
fansc9996e1f
Bahamas
Yes it's a dji phantom 3 standard
2017-12-16
Peterx
Flight distance : 1499708 ft
Did you put the  WIFI on and searched for P3S WIFI in the network list ?
2017-12-16
