DJ assistant Calibration stops at 85% [ SOLVED ]
123
25162 83 2016-12-28
djiuser_3Ra8hlgOuDYO
India
Calibration is under process it can be stop in 85% and doesn't running please give me one suggestion
2023-8-7
DJI Tony
djiuser_3Ra8hlgOuDYO Posted at 8-7 04:25
Hello there. Sorry about the late response. Are you still having the same issue? and may I please know what is the model of your drone? Also please try the steps below and see if they will help:
1. Check whether the vision lens is dirty.
2. Calibrate the sensor status on the calibration page. If one image is black or gray, it indicates that the sensor is malfunctioning. Please send the drone back for repair.
3. Use the latest version of DJI Assistant 2 and update the firmware to the latest version.
4. We recommend using a monitor larger than 14 inches.
5. Set the monitor resolution to the default recommendation value for the system (Generally: 14 inch: 1366*768 or 1440*900; 17 inch: 1366*768 or 1280*720; 19 inch: 1366*768 or 1440*900; 22 inch: 1680*1050 or 1920*1080; 24 inch: 1920*1080 or 1920*1200).
6. Restart the computer and aircraft several times.
Please keep me posted. Have a great day ahead.
2023-9-21
Dunghy
Vietnam
DJI Tony Posted at 9-21 03:46
2. Calibrate the sensor status on the calibration page. If one image is black or gray, it indicates that the sensor is malfunctioning. Please send the sensor back for repair.
oh no!! it max 85%. i thing it don't forget
2023-12-31
DJI Tony
Dunghy Posted at 2023-12-31 17:29
Hi, Dunghy. I hope you are doing well today. If you are also experiencing the same issue as above. Please follow the suggestion in reply 82#. I will look forward to your reply. Have a great day.
1-1 02:29
123
