Keep getting strong interference on remote controller and weak si...
3929 7 2016-12-28
fai58
Flight distance : 104439 ft
I flew exact same location over 20 times, and I had never received any warning messages about strong interference and weak signal until today.  Had anyone run into this problem?  I just upgrade to latest firmware, the first flight after the firmware upgrade was fine, this 2nd flight was problematic.  But one thing to noticed is that I was using a different battery.  Not sure if that could cause it.
2016-12-28
DJI-Ken
Flight distance : 1515312 ft
I don't think the battery would have anything to do with it.
Can you try some different areas, also you have the antennas in the correct orientation right?
You can also perform a factory restore from the Assistant2.
And make sure you have a good compass calibration.
2016-12-28
fai58
@ken, the antennas was always the same way I had used since getting the mavic on Oct 25. I'll try it at some other locations, but I was just worry if the messages will cause any issues later
2016-12-28
fai58 Posted at 2016-12-29 10:13
Please keep us posted and be careful.
2016-12-28
fai58
I removed my Apple Watch after that incident and it has never happened again, perhaps the Bluetooth or something magnetic affect it
2017-1-1
fai58
@dji-ken, it happened again even after I removed my Apple Watch. I'll try to turn off wifi to see if I'm getting it.
2017-1-5
GECHO
Flight distance : 18504 ft
Philippines
fai58 Posted at 2017-1-5 11:17
I had the same error on a 15 minute flight. And this error showed up about 2 minutes on flight and caused distance to be off on the app. When I tried to land I was not able to control the Mavic and crashed.
Here is a link the flight video log.
2018-4-9
GECHO
Philippines
GECHO Posted at 2018-4-9 08:53
And I have flown from this location more than 20 times and just had this problem once.
2018-4-9
