SPeedyG
RE: PGYTech filters
Just got the 4 pieces ND filter kit today (4,8,16,32) and I can tell you that the PGYTech filters don't seem to have any issues with the Gimbal initialization.
I had tested all the 4 of them as one user in another thread complained about one filter out of the series that didn't pass.
It is very easy to put it on the Mavic lens (it has some foam glued to the inner ring of the filter.)
So for those having the issue, I can only guess that it is either an older version with different geometry, or simply a user error - i.e filters were not installed correctly.
BTW, The ND16 also seems darker than the "no brand" I currently use.
That's also the reason i got a set with a 32, for the SOCAL sunny days, as the ND16 I had till now was not dark enough, probably only as dark as the PGYTech ND8.
Anyway, I will put it to test in the coming days and see whats the Video output with these filters. |
