Aardvark
Flight distance : 384432 ft
freelanderuk Posted at 2016-12-31 05:32
I have the same problem ,updated to the latest firmware on the p4 ,602 on the a/c ,1.8.0 on the r/c ,the battery that was in the p4 whilst updating is now showing battery signal error ,the second battery updated fine in the drone and is working OK ,I can not get dji assist to connect to my p4 on my windows pc ,how can I roll back the firmware, both batteries were working fine before the update
Cheers
Chris
If you wish you can roll back firmware on P4 via DJI Go App'. Although I always use Assistant 2.
Connect and power up device, RC and aircraft.
On the front page in DJI Go (I'm using DJI Go 4, but DJI Go 3.1.1 is same idea).
Hold your finger on the icon at top right of page (three lines) for five seconds or so. Then remove finger.
You should get a black screen appearing with a menu asking you to 'select firmware version', tap on that and you should be given a choice of which version to move back too. The previous to 01.02.0602 was 01.02.0503. Select that and then hit download. When rollback completed repower all devices. And that should be it, whether is will help with battery report I do not know.
p.s. make sure you have a good wifi connection.
