Enkeixpress
Flight distance : 297497 ft
Am I the only one experiencing this error message coming up every so often? Compass error, switching to redundant compass, or something like that. It happens within 2-3 minutes after takeoff in both GPS mode and sports mode. I've only had the Mavic Pro for around 2 days now. Flew at least four flights so far at two different locations. One that's very wifi congested and the other a large open field, mostly parkland with no trees. I never used to get this with the Phantom 4. There's a red bar at the top with compass error - move away from aircraft or calibrate compass which I've done many times both before and after each flight. It's more of an annoyance than anything else as it doesn't affect the flight at all. Just odd to see it switching from green GPS mode to that message constantly.
Was going to capture a screenshot of the error message but it's a tad bit difficult to hold the home button and the power button on the mobile while it's in the device holder.
Pretty sure it may be an firmware issue that needs sorting out with a new firmware, as it happens a little too much to be seen as normal.
