OuraybyFlight
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Flight distance : 1692195 ft
DJI Mindy Posted at 2016-12-30 02:43
Hello, this issue may occur if the gimbal is skewed due to shaking in transportation, and the rubber gimbal ring moves toward one side. To fix this issue, manually rotate the gimbal in the opposite direction of the tilt until it reaches its limit. Do this several times, and the gimbal should be centered.
Thanks Mindy - These seemed to fix the problem for me (and the problem was driving me nuts!). If the camera was slightly off-center like this, would that also cause light jello in the video?
Also, while this did seem to fix the off-centeredness, it seems to creep back after a a restart or another flight. I don't want to have to be manually pressing on the gimbal all the time. Is this problem permanently fixable?
