CineView Media
Flight distance : 5365522 ft
Norway
I consider no questions regarding the manual as stupid, so therefore,
"Stopping the Motors
There are two methods to stop the motors.
Method 1: When Phantom 4 Pro / Pro+ has landed, push the left stick down , then conduct the same CSC that was used to start the motors, as described above . Motors will stop immediately. Release both sticks once motors stop.
Method 2: When the aircraft has landed, push and hold the left stick down. The motors will stop after three seconds."
Is the Phantom inteligent enough to tell if its in air or on the ground when using Method 2?
On descend i often pull the left stick down continously...
