VPS not working
2515 17 2016-12-30
ulyssesneto
Brazil
I'm new here. MAVIC is my first drone. I bought this Monday and flight only two times. When I takeoff at third time, the aircraft not get the correct altitude, and not stable.
I try to upgrade to resolve, but no effects. I downgrade and not solve.
The radar is enable from remote control, but the CLEREANCE information only show "--"; and on DJI GO APP; the VPS information desapear. The radar signal at DJI app disappear too.
I don't know what can I do to solve it.
I think that's a firmware problem, not physical problem.
Thanks and sorry for my English.
2016-12-30
Hello ulyssesneto, "Disconnected" means your phone is not connect with RC successfully.
Could you please clarify what mobile device you are using?
Have you tried to change another original usb cable or lightning cable to connect your phone with RC?
2016-12-30
ulyssesneto
Brazil
DJI Mindy Posted at 2016-12-30 19:57
Mindy, I just put this screen to show that the VPS disappears at the button.
The radar information, like a proximity sensor, never appear.
I print this without the aircraft.
2016-12-31
ulyssesneto
Brazil
Look the VPS not show at screen.
2017-1-2
Danny-B-
Flight distance : 306640 ft
ulyssesneto Posted at 2017-1-2 12:47
VPS is disabled in your screenshots ... have you enabled VPS in the settings?
VPS will also disable itself when the ambient light isnt bright enough.
2017-1-2
ulyssesneto
Brazil
Danny-B- Posted at 2017-1-2 13:32
How Can I enable?
I try turn on ENABLE OBSTACLE but doesn't happen.
2017-1-2
Anthony566
Flight distance : 2488944 ft
http://www.dji.com/mavic/info#downloads
Have you looked at the full userguide ? It is very helpful
2017-1-2
Anthony566
If you tap on the Red icon it will take you into the VPS setup screen then just enable it by touching the buttons on the right side of the screen.
2017-1-2
ulyssesneto
Brazil
Anthony566 Posted at 2017-1-2 17:19
Look these prints. I tried many options, but no effect.
2017-1-2
Anthony566
Ok good but it is night time .. vps ONLY works in good lighting so day time mainly
2017-1-2
Anthony566
Or indoors with very good lighting
2017-1-2
Anthony566
Also i noticed from you imige that you do not have a memory card in your mavic ... dont forget to put it back in
2017-1-2
ulyssesneto
Brazil
Anthony566 Posted at 2017-1-2 18:06
Thanks for the alert.
Tomorrow I'll try at the day.
Probably don't work. And if not, I'll send photos.
Thanks
2017-1-2
Anthony566
Good luck
2017-1-2
ulyssesneto Posted at 2017-1-2 18:09
Besides, neither GPS nor vision positioning is available in ATTI mode.
Please keep us posted.
2017-1-3
ulyssesneto
Brazil
Thanks all for attention. The DJI replace my aircraft. The problem with the sensors can't be solved easily.
2017-1-4
Termite
My VPS has been red and disconnected for the past 5 flights tried re calibration and still no dice
Did DJI replace the drone ?
2017-1-4
ulyssesneto
Brazil
Termite Posted at 2017-1-4 11:46
It's better you contact directly DJI to solve this.
2017-1-4
