DJI Phantom 3 Standard Flight Range Only Reaches 100m
7590 27 2016-12-30
AMH
Hey i recently started to use my dji phantom 3 standard and only to find out it was not capable of reaching the full 1km range (because it losses signal) it advertises as i could only get it 100m range.how do i get the full 1km range?
2016-12-30
Hello AMH, the Max Transmission Distance for FCC country is 1000 m, for CE country is 500 m. And it's under ideal situation.
Possibly you ran into interference in that area. Please try to fly in another open area to see if it's the same or not.
Also, make sure your antenna in correct orientation.
2016-12-30
SPARKFLASH
Flight distance : 63743 ft
Or does this have the same limitation as the one I have?  On mine it said in beginner status it limited to 100m.  I had to turn that off to go farther.
2016-12-30
Phantom-Paul 7
Flight distance : 2551634 ft
Do you mean it loses radio signal at 100 meters or it won't let you fly further than 100 meters?
2016-12-31
Hkdman
sounds like you have the beginner mode toggled.  Turn it off.  With it on, you are limited by how far and how high you can go.
2016-12-31
LoganRisen
Do you have beginner mode on? If so turn it off by going into Settings> Main controller settings> Beginner Mode and switch it off.
2016-12-31
AMH
Phantom-Paul 7 Posted at 2016-12-31 05:29
Losses signal
2017-1-1
RedHotPoker
Flight distance : 165105 ft
We can't help laughing. Seeing my old avatar from last month, used by a new forum member. Hahaha
I thought I had buried that Lame Duck, deep enough? ;-)
RedHotPoker
2017-1-1
fansea8ff0df
Flight distance : 14715 ft
A year ago i purchased the standard. Range was okay. Didnt really get 500m but range was okay for my use. Couple weeks ago i updated firmware and noticed that range was less and it kept going into return to home mode due to signal loss.  Not sure if latest firmware is to blame?.
2017-1-1
Phantom-Paul 7
Ok so does it RTH or do you just loose the video/telemetry ?
Are you flying in a clear open area away from buildings (especially metal roofs etc... ) and electrical noise ?
Because the P3S uses normal WiFi it is very susceptible to outside signals and noise which can really knock its range down.
Flying in open areas over lakes and paddocks etc.  mine easily gets 500m before the video feed gets jerky ( I am in a CE country so have the shorter range settings :-(  )  but if I come fly in built up areas , especially where there are metal roofs the signal can drop out instantly at 200 m.
2017-1-1
Phantom-Paul 7
fansea8ff0df Posted at 2017-1-1 03:00
Did you do the FW update via the Go App or force it via the SD card?
What version FW does the App report now ?
2017-1-1
fansea8ff0df
Phantom-Paul 7 Posted at 2017-1-1 03:55
It was done through the Go app. I cant remember what version it was updated too but did notice reduced range since update. I even tried the ARGTEK mod on transmitter which didn't really make any difference. I have now got the Advanced and dont plan to update unless i really need to.
2017-1-1
AMH
Phantom-Paul 7 Posted at 2017-1-1 03:53
I fly over lakes and it just looses video and says looses signal and I have to Bring it home manually without auto RTH.
2017-1-1
AMH
2017-1-1
Phantom-Paul 7
AMH Posted at 2017-1-1 05:37
When it looses video does the telemetry still work IE eg the altitude , distance and speed?
I am trying to establish weather you are loosing the WiFi completely or just the video feed.
There appears to be a couple of different problems with just the video - one caused by the app and one caused be the camera.
If on the other hand your loosing the WiFi completely we need to look else where.
How old is the Phantom?  Can you return it under warranty  before we fiddle too much?
2017-1-1
AMH
Phantom-Paul 7 Posted at 2017-1-1 05:50
I Think I read somewhere that there is a screw u can twist on the back of the controller to extend the range
2017-1-6
BillW50
AMH Posted at 2017-1-6 00:50
You are thinking of the Phantom 2 controller. The Phantom 3 controller doesn't have that adjustment.
2017-1-6
AMH
DJI Mindy Posted at 2016-12-30 20:23
I'm in Australia and that's an FCC country
2017-1-7
Phantom-Paul 7
Nope Australia is a CE :-(
2017-1-7
AMH Posted at 2017-1-7 02:42
Just as Paul 7 mentioned, Australia is CE country.
2017-1-9
Rene Jensen
Denmark
what firmware is in the aircraft if its 1.6.8 thats the problem the newest is 1.7.9
2017-1-9
8ball
Rene Jensen Posted at 2017-1-9 22:37
where do I go to find the firmware version?
2017-1-12
Rene Jensen
Denmark
in the go app under about thereis the firmware version an the app version
2017-1-15
8ball
Rene Jensen Posted at 2017-1-15 01:21
the only thing i found there is the app version 3.1.1.. but nothing about the firmware the drone is running. i did do the latest update though, but would still would be nice to know where to find it when needed. my p3 just does not seem to be performing very well over all. video, hight, distance, and power are all poor. nothing like when it was new, and it is not even a year old.!
2017-1-15
Kgfservices
I'm in the uk and can get well over 500 metres in the valley where I live with clear sight
2017-1-27
Anonymous1
Flight distance : 602303 ft
Jamaica
Phantom-Paul 7 Posted at 2017-1-7 06:02
Is there somewhere I can go to see the list of FCC and CE countries?
I'm trying to determine my drone's status here in Jamaica.  I should be getting it in hand today.
2018-8-21
Mark The Droner
Flight distance : 2917 ft
My understanding is that FCC is USA and CE is everybody else.
Good luck
2018-8-21
RedHotPoker
Anonymous1 Posted at 2018-8-21 09:16
Your drone will know... ;-)
Still LMAO, seeing the OP using my old avatar.  Lame Duck!! Hahaha
RedHotPoker
2018-8-21
