probonic
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Flight distance : 61211 ft
I am no photography expert, but I do know a bit and use ND filters myself. You are spot on in that they simply reduce the amount of light hitting the sensor. ND stands for "Neutral Density" and refers to the fact that it reduces all wavelengths equally, as opposed to only certain colours or UV etc. The ND4 and ND8 numbers mean how many "stops" it reduces it by, but basically just means ND8 will block more light than the ND4 filter. On a normal camera you would change the aperture, but Phantom cameras have a fixed aperture, which is why you need to use ND filters if there is too much light.
One common use for ND filters is reducing the so called "jello" effect, where vibration is seen in the video. It does this because as the light entering the camera reduces, the camera is forced to lower the shutter speed to get the same exposure, and this generates some motion blur as the light hits the sensor over a longer period of time. This motion blur helps to mask the effects of the vibration.
You can leave the settings on auto if you want, and the Phantom will adjust the settings automatically to get the right exposure. If you switch to manual settings, you would need to reduce the shutter speed to brighten up the image to compensate for the lack of light the filter causes. |
