Controller right stick won't calibrate
2419 8 2016-12-31
Goldenboy
I have had my Phantom 3 Standard for about a week now.  Everytime I attempt to calibrate the controller using the Go Ap the right stick does not calibrate.  If I do get it to work in the calibration process and fly it looses calibration.  I turn the Phantom off to try the calibration again and the right stick is either showing 100% in the up position but the stick is actually centered.  Sometimes when I try the calibration the right stick only shows moving the stick to the right or left but not up or down.  I have calibrated the IMU several times and the app is showing the most recent firmware.  Any suggestions??
2016-12-31
MrPinaColada
Flight distance : 790082 ft
What mode is your transmitter in?
2016-12-31
Goldenboy
MrPinaColada Posted at 2016-12-31 17:16
Both auxiliary switches are in the top positions
2017-1-1
MerlinL14
Flight distance : 2858 ft
In the DJI app there is a menu to put the transmitter into Mode 1,2,3 or 4 or even configure it to your preference. It has nothing to do with what switch position you are in. You need to acces the DJIGo app and select Mode 2 (or whatever is your preference).
2017-1-1
Goldenboy
MerlinL14 Posted at 2017-1-1 07:43
Misunderstood the original question,  the transmitter is in Mode 2.
2017-1-1
Tahoe Ed
Flight distance : 41668330 ft
If you cannot calibrate your RC.  Then you need to contact dji.com/support for a repair replacement.  We would like to see a screen shot of what you are seeing.
2017-1-1
Goldenboy
Tahoe Ed Posted at 2017-1-1 08:16
I am trying to send the screen shots.
Right stick down
Right stick down
Right stick up
Right stick up
Right stick right
Right stick right
2017-1-1
Goldenboy
Returned the Phantom 3 to the store and exchanged it for a new one.  So far all of the calibrations are working on the new drone.  Thanks everyone for your assistance!
2017-1-1
0585
Hello, I  am able to complete the full square of the left stick when calibrating my mavick after getting the stick err sign, but then I can't continue to the right stick it stops on the left one. Any advice?
Thank you
2019-2-3
