Controller Mode 1 or 2?
5251 14 2017-1-1
Harborseal
Hi!  Before my P4P gets here I'd like to learn on a simulator.  To get the right controller I need to know which mode the Phantom Controller operates in.  It doesn't say on the spec sheet.  Is one mode more common than the other?  Thanks.
2017-1-1
CineView Media
Flight distance : 5365522 ft
Norway
Its actually just a matter of taste.
Originally Mode 2 is commonly used in US and Europe, Australia and Asia often use Mode 1.
The advantage of getting used to Mode 2, is that its easier to relate to other equipment later that might not have customizable modes
2017-1-1
Harborseal
Thanks. So you're saying the Phantom can operate in both - that it's switchable?
2017-1-1
CineView Media
Norway
Yes, you can change it trough the Go App under remote controller settings and stick mode.
2017-1-1
Harborseal
Thank you.
2017-1-1
marksy
Flight distance : 42792 ft
Mode 3 for the win.
2017-1-1
Brad M
with go 4 you can see and play around a little with the modes without having to be connected to craft.
2017-1-1
DJI-Jamie
Flight distance : 112405 ft
You will get the option to choose during initial set up and then can change it at anytime via the RC settings section of the Go app. You can even take it a step further and can create a custom stick control, but that's really for those that are either a little more skilled or really do not like fitting into a particular mold.
2017-1-1
DJI-Jamie
Are you referring to the custom controls, or is there really a mode 3 I'm not aware of?
2017-1-1
marksy
DJI-Jamie Posted at 2017-1-1 15:23
Yes, there is a mode 3 and mode 4.
Mode 3 is similar to playing PS4, I find.
2017-1-3
Aardvark
Flight distance : 384432 ft
Mode 2 would likely be the most commonly used, it being the default.
2017-1-3
RoadmasterD
Flight distance : 188527 ft
Without a doubt, mode 2 is the most common I've ever seen with virtually any RC aircraft.
2017-1-3
marksy
RoadmasterD Posted at 2017-1-3 16:52
Last time I tired flying mode 2 with my race quad, it was almost the last time I saw it. Lol.
2017-1-12
Harborseal
Thanks, guys.  I just got it  in, updated the aircraft's fw and am working my way through setting up Go4
2017-1-14
Yves Mattle
Flight distance : 74944 ft
Switzerland
Brad M Posted at 2017-1-1 14:54
Vor 5 Jahren konnte man noch selber Einstellung und so mit Modus 4 einrichten. 5 Jahre späte mit neuen Drohne funktioniert das nicht mehr ?
LoL
2022-9-25
