Setting Video Format ?
1906 4 2015-2-14
cpslutz
Flight distance : 2722556 ft
Ok, running iOs v 1.0.1 on iPad Mini 2.  In beta iOS version, there was a video format button (MOV or MP4) on the camera FN menu.  I don't see it there now and find it on the General settings (upper right corner) menu.  OK, I select MP4 and NTSC, a box says the camera will restart.  Later, if you re-enter the menu, the format button has moved back to MOV, though the camera is still set to MP4.
Is your v 1.0.1 behaving the same way?  My memory may be going, but thought the video format button was on the FN menu and went away after I played with camera FN while in the simulator.
2015-2-14
RickRoberts01
Flight distance : 191575 ft
I am experiencing the exact same thing, cant change to MP4
2015-2-14
cpslutz
RickRoberts01 Posted at 2015-2-15 01:46
Rick....my camera is set to MP4, even though the buttons keep bouncing back to MOV and PAL.  Assume the restart actually makes the change.  Test it.
And... the Shooting Mode button at bottom of FN menu (switches from manual to auto).  Does not work for me, same with you?
2015-2-14
Ton.veenhof
cpslutz Posted at 2015-2-15 01:56
Rick....my camera is set to MP4, even though the buttons keep bouncing back to MOV and PAL.  Assum ...
Although this is a 3-month old topic.... I can't even find the menu to change the MOV format that my P3 is generating to MP4 on my iPhone 5. Should I be able to find it or does the Pilot app differ on a tablet?
Thanks,
Ton
2015-5-18
Ton.veenhof
Ton.veenhof@gma Posted at 2015-5-18 22:15
Although this is a 3-month old topic.... I can't even find the menu to change the MOV format that  ...
Found it! Had to scroll down a bit more in the app... Sorry.
2015-5-18
