Geebax
DLS0680 Posted at 2017-1-2 15:38
At the beginning of the video and at about 20 second mark in the video you can see what I would describe as flickering. You can really see it if you look at the trees on the right side of the video at the 20 second mark. It's not smooth it looks kind of jittery and not really super clear. I think the clarity is due to the downgrading the video to 720p also kind of washed out from facing in the direction of the sun. Could these lines be from some type of vibration or from the wind or a combo of both?
No, they are called prop shadows, caused by the angle between the sun and the lens. The prop is then in bnetween the sun and the lens and casts shadows onto the lens. The speed on the prop verus the can rate causes those lines. You can mitigate them by adjusting the tile anlge of the camera to some degree. |
