Mark97564
Flight distance : 2067749 ft
You have it set for single video source.. Set it to dual video source on the master lightbridge unit so both video steams come down from the air unit... Let me know if it helped you, I'm pretty sure that's your only problem.. The setting you need to change is right above where you select which camera you want to see.. You can't play a different camera source on each lightbridge if you only have the air unit set to send only one source.. Set it to dual video source and then the air unit will will send both camera streams down.. It has to be changed on the master ground unit, in the slave unit the setting is greyed out and can't be selected.. So where you select what camera you want displayed right above that it says it's set to single, just tap on that and change to dual and I'm sure it will be fine..
Please let me know if I was able to help you or not
