Cave flying without GPS prevented by Height limt
3368 7 2017-1-3
DreamerPix
Flight distance : 127438 ft
Singapore
Just got the MAVIC and was visiting a cave and it was large enough to fly the MAVIC.
The problem I have is that there is not GPS Signal and it was switch to ATTI-MODE which limited me to the 3Meters if i am not wrong which is completely useless to flight around.
The cave is huge with some 20-30 meter height ..
Is there a way to overwrite the height limit in ATTI-MODE when there is no GPS?
2017-1-3
StianGel
Flight distance : 686654 ft
Norway
If you disable the VPS, you should get a few meters higher.
2017-1-3
Danny-B-
Flight distance : 306640 ft
I'm not aware of any height limit other than normal flying height ... Atti mode shouldnt restrict height at all and i'm sure VPS wouldnt either, unless its detecting an obstacle (it cant detect things above it anyway ... )
2017-1-3
MarcusPolus
If you get it to work, I hope you post solution
2017-1-3
colinwebb
Try flipping it into sport mode to get to your desired height and then going back to the regular mode.
2017-1-3
Jimney
Flight distance : 103268 ft
See page 49 in the instructions - if GPS is weak ie switched into Atti mode max height is 5m with VPS ON & 30m with VPS OFF.
It doesn't appear that currently there is a user option to overwrite these heights.
Hope this helps
2017-1-3
DreamerPix
Singapore
Now already leave the cave will try again ... I did switch to sport mode and manage to get some height but there was a 40-50m hole above the cave where I can see the sky...
Did not manage to get the shot I want ...
Btw : I will check how to turn VPS on and off
Thanks guys
2017-1-4
fans575cb15c
Lithuania
@DreamerPix ...I just saw your post.
There is a fix for it. You will have to connect usb on drone with pc and use the assistant soft. Just like before in Nazam M V2 for phantom . There will advance settings> limits
There you will see
Max height and Max radius limits.
So you will have to reset that as per your need.
Once this is done start your drone ...fly in Manuel mode.
Now even if it starts in altitude mode your default height changes will be applied say if you set 40m
As by default in altitude mode it's was just 3m .
2017-12-6
