jason.kirkman.y
Hi all had my phanton 5.8ghz fc40 for 3 - 4 days done 6-8 flights and today have seen red lights all the time unsure why??
I have 3 batterys all were fully charged as i have a volt tester showed 12.5v
After 3-4 mins flying i saw the red light flashing none stop so came near me and landed, changed battery and went up again after 3-min max red lights again? last battery and same maybe 2 mins
When i initially started up had yellow red flashing lights so was aware this had something to do with compass so i moved well out the way in field callibrated compass and all lights were as normal yellow green flashed 4 green the red red red green until 1 red and green and then 20 green again. I went out 30' and turned round and tried home lock (2 down) and came back to me as should but never stopped went over my head.
I landed near me and tried to resest failsafe lock put s2 left toggle up down 10 or so times but no lock came on maybe to near previous position not sure but anyway decided to stay very low and go a bit further out thats when i started seeing the red lights? so came back to land. changed battery twice and all seemed to boot up fine green red and 20 green very quick then red red green until another 20 green.
Got home checked voltage and 11.9, 11.8, 12.1 the battery with one battery the phantom would not even take off not enough power in motors even though 11.9v now in battery.
Pluged in laptop and naza says no errors (or where do i look to see them??) all buttons work on transmiter and move in naza says IMU doesn't need calibrating? shows 0.2 + -3 on gyroscope. and -239, 84, 298, 1329 on compass and mod.
Oh my transmitter just beeped twice while in naza flshed green i have duracell in them and only done a few flights? only other thing is callibrate transmiter?? but all buttons seem to work fine??
Battery voltage says 11.7 and is set at default 11.55 and 11.10 no load and loaded?
What could it be all i can think to do that i have not done is magnets over the compass but i don't even know if this has anything to do with it. The compass is fine when i do the callibration pre flight yellow then green and then starts flashing as it should.
Just been in back garden and same only when in air red lights come on when land goes back to red green. Apart from 1 battery which was flashing red all the time.
Any ideas???
Thanks |
