Nigel_
Flight distance : 388642 ft
You can easily relocate and then grab it while it is in RTH if you hold the throttle up while it is still above your head, then leave go of the throttle and the motors will stop. Possibly safer than cancelling RTH, since then you have to pull the throttle down to stop the motors while also holding the aircraft steady. Just make sure to land it where there is nothing to trip over so that it doesn't land on top of you! |
