Phone charging from RC
630 7 2017-1-4
GZP
Latvia
Anybody had such case? My mobile phone charging from the remote control. LG G5. RC rapidly losing power. Any idea how to avoid it? Found some comments that RC charing from phone, but not on the other side.
2017-1-4
Willik
Flight distance : 638796 ft
Czechia
Hi, I guess it's normal, My Galaxy S5 is also being charged from the RC. Even then I am able to fly approx. for an hour (3 Mavic batteries).
2017-1-4
WYHSniper1007
Flight distance : 1003822 ft
Android phone will be charged by the remote, iPhone won't. So I think dji will update the software soon
2017-1-4
The charging current is very little. Please don't worry about it. It's recommended to full charge your mobile device, RC and aircraft battery before your flight.
2017-1-4
Jason Lane
Flight distance : 260144 ft
Philippines
If your G5 is draining the RC quite quickly, you can try using the bottom USB port of the RC instead of the side. I have the same problem with my Galaxy S7.
2017-1-4
ocelot27
Flight distance : 1163894 ft
Jason Lane Posted at 2017-1-4 22:33
second that - larger center USB port doesn't seem to supply any current
2017-1-5
StigNygaard
Flight distance : 357169 ft
Denmark
I've also seen a slight charging effect from the RC to my Android Google Pixel. I don't think of it as a problem, since RC has a pretty big battery it might just be seen as an advantage to keep your phone running.
It would be worse the other way around which is the problem I hear some iOS users has. I imagine the RC could drain a phone battery pretty quickly...
2017-1-5
Jason Lane
Philippines
StigNygaard Posted at 2017-1-5 09:39
A slight charging effect sounds pretty normal, but what I experienced was my RC going from 100% down to low-batt warning after only about 1.5 flight batteries. After switching to the bottom USB port, I can now fly three batteries and still have over 40% left on my RC.
2017-1-5
