P4 Serial Number
17212 9 2017-1-4
pmmonte
I'm trying to locate the Serial Number on the drone and I'm not sure if I'm looking at it on the tag inside the battery slot.  Anyone know?
2017-1-4
BashP4P+
I found it on my box. its also is inside the battery compartment.  Not sure about the p4 but on the p4p+ its written over 2 lines. its pretty much as you look into the compartment on the bottom side facing you. right at the opening.
0AXXDDAAA
0AXDDASW
the 0 on mine was the number zero.  I needed it to buy the DJI Refresh and I had to enter it all in one line together.
0AXXDDAAA0AXDDASW
Apologies if the P4 is totally different. Hope that helps.
2017-1-4
pmmonte
BashP4P+ Posted at 2017-1-4 18:44
0AXXDDAAA
0AXDDASW
No, I think you're spot on.  Mine has two lines, but I wasn't sure it was the serial number or not.
Thanks!
2017-1-4
DJI Natalia
Flight distance : 318 ft
The SN for P4 is located in the battery compartment, here is the screenshot for your reference:
2017-1-4
DJI Natalia
0AXXDDAAA
0AXDDASW
Thanks for your detailed explanation, it's same for P4 and P4P+.
2017-1-4
DJI-Jamie
Flight distance : 112405 ft
pmmonte Posted at 2017-1-4 19:19
Thanks!
You're correct, Natalia also provided pictures for reference. Because the S/N is so long it's split up with the top part being the first line of the S/N.
2017-1-4
djiuser_RUK12KnA5lkt
I bought a new DJI Phantom 4 from Amazon through a place called shutter stop and when I received i was locating the serial number on the Drone and the Box. There is a sticker with a serial number over the original serial number printed in the battery compartment which are different numbers. The labeling on the box also looks like it's not the original. Can anybody enlighten me on what I just bought claiming as new?
2018-12-8
MRomine
Flight distance : 850971 ft
0AXXDDAAA
0AXDDASW
How do you know if '0' is the number 0 or the letter O on the P4 SN?
2019-1-3
aerovideos
Flight distance : 799268 ft
Hi
Can you let me know what you know about the Phantom 4  activation, serial number 07DJE160C10300 and also  the guatanty end ?
Thanks
2019-11-27
aerovideos
Hi
Thanks
2019-11-27
