JasonMBryant
MuzzDrone Posted at 2017-1-20 00:50
I managed to solve this on my Mediapad after having the same problem as you.
Select settings, then select Display, then select View Mode. In View Mode select either small or large (whichever is your preference) and then hit apply. The tablet will then reboot and you will find the problem is fixed in the Go 4 App with all menus working perfectly.
For some reason the problem only appears if the view mode is set to Medium, but small or large works just fine.
Thank you, but I don't have that option. |
