Active track defaults camera to 4k30p Issue ??
651 5 2017-1-4
Nil73
Mexico
Anyone using active track on the P4P+ find that it defaults the camera to 4k/30p from whatever format you were using before.??
2017-1-4
DJI-Jamie
Flight distance : 112405 ft
Just to clarify, are you setting up active track before or after the camera settings?
2017-1-4
Nil73
Mexico
I for example am filming in 1080/60p, then I change mode to active track, when I do this the drone changes to 4k/30... and on exiting the mode it doesnt change back.. I can also change the mode back to 1080p or another format while in active track.. Seems like a bug and its very annoying..!!!
2017-1-5
P4P+
Same here. I set the camera up to shoot in 4k 60, used Active Track and when I looked at my video setting later it was now set to 4K 30. The video from Active Track looked good because the person and camera were always in the same relative position so there was no out of focus on yaw, but I didn't realize that I had to reset the camera to 4K 60 for normal shooting.
2017-1-11
P4P+
DJI-Jamie Posted at 2017-1-4 23:35
I am setting up active track after setting the camera to 4k 60 but the video gets shot in 4k 30 and the video setting stays at 4k 30 until I change it back.
2017-1-11
richparry
Flight distance : 1620148 ft
P4P+ Posted at 2017-1-11 18:05
Just thought I add that I see the same thing, I set format to 3840x1080 or 1920x1080 and the resulting file is always 4096x2160. This is a bug.
At a minimum there should be a WARNING NOTIFICATION that settings are being changed.
Rich
2017-1-11
