Geebax
JasonT2013 Posted at 2017-1-5 06:44
I've put a link to the video below. The video is off of the sd card not my phone. Please let me know if you guys see anything I should be doing differently!
Settings:
I looked that footage and there is nothing wrong with it at all. This is your winter time, and whispy tree foliage makes it a bit harder to encode, but you have dialed down the sharpening, so did you not expect it would be less sharp?
When you says the foliage is just blobs, what are you using to view the footage? If you import that material into a good editing program and colour correct it, increase the sharpness, it will look just fine.
I notice you have used D-Log, if you are not experienced in colour correction, then it would be a good idea not to use D-Log, because it requires a lot of work to make it look good.
