Hkdman
A couple of quick questions. First off - I am definitely getting more confident in my flying! I am trying to extend my flight distance a little more each day. Using the Litchi App, I have 2 quick newbie questions:
1) I fly a P3 Standard. After anywhere from 800 - 1300 feet away at a height of 300 feet - I will lose connection. I get a red "DISCONNECTED" indicator on my Litchi app. I seem to lose both video and the tracking on the app. I am flying in heavy residential, but the buildings are all houses that are typical suburban (10-15 feet high strucutres). I have ordered one of those cylander range extenders, but is this range about what I should expect?
2) Also - I have seen some coflicting information. I have read that when I lose connection, the mission will continue to run until the very end (I just won't see it on the map or video). However, I thought I read on the Litchi instructions that for the P3 Standard, when you lose connection, the drone will just hover in place at whereever you lose connection. I must admit, I get a little nervous when I cannot track on either the map or through video so I usually freak out and hit the RTH - but if I leave it alone, will it run the mission on the P3 Standard? I always have the last waypoint set to be really close to the first waypoint as a precaution - so I would feel comfortable if it ran the mission but I just wanted to get confirmation since like I said it is kind of freaky when you don't see anything.
Last question (I promise) - I downloaded the new DJI app that does the waypoints - any thoughts on the pro / con of this app versus Litchi?
Thanks!
