Gary Mac
Flight distance : 741683 ft
JMHO:
"the camera appears to be of equal or less quaility than the P4" - As far as I know, the camera specs are equal to (and video appears at least as good as) the P4
"tap to focus" - Is now optional, as the software continually auto-focuses the camera. (Something I GREATLY appreciate)
"cannot record 1080P at 60fps" - I haven't tried this. I have recorded exclusively in 4K, so it hasn't been something I have missed, if it is not capable of doing it.
"less capable in strong winds" - I would disagree. The Mavic has a lower side profile and has less to be "pushed" against. I have had it up in some windier conditions and I receive the warnings to be careful, but it flies and records like a pro.
"low ground clearance" - True, and there are several simple solutions, from ad-on stilts to just carrying a simple landing pad. I chose a landing pad to keep debris from the ground to a minimum. It stores in a 10" diameter case. This "low ground clearance" is also what helps make it so portable.
"Then there is the multitude of issues that I keep reading about on this forum" - People complain WAY more than they compliment. When things work, people spend their time enjoying them, not taking breaks to go and tell their friends and strangers how well things are going. So, if you take into account that people will complain FAR more than they will praise, then add to that the number of people who don't read the manual, don't follow common sense, and fly the Mavic like it is an idiot-proof, bullet-proof consumer toy, you get a good idea of the bias that is seen on the forum.
The Mavic has some issues. Roll-out sucked, there are some bad copies that were sent to buyers, the firmware could have been better to start with and is still not as good as it should be, and we have yet to see ALL the potential issues that may have to be addressed by DJI with regard to the Mavic. So, if you are willing to carry around your P4 (and the considerable size) just to ease your conscience, then I would do it.
The Mavic is BRAND NEW and, just like any other BRAND NEW tech, it will have some growing pains. The P4 built on the P3, but the Mavic was designed new from the ground up. However, if you can appreciate how incredibly convenient the Mavic is to travel with, how easy it is to fly, how stabile it is in the air (in my experience, it appears to be more stabile than the P4) and accept that it is a small percentage of Mavics that are having issues, then I suspect you would be just fine upgrading to the Mavic. If you buy the Mavic, buy the DJI Refresh, give it a thorough testing as soon as you get it and then enjoy your new (better) camera platform.
Again, JMHO.
