Nigel_
Flight distance : 388642 ft
"then you stretch the darks down and the whites up... then you'll get noise and poor color depth... right?"
If you want to end up with it stretched, or modified in any other way then it is best to do it while it is still 10bit raw data, before it is encoded into 8 bit compressed data and all the non-visible detail is thrown away. That applies to contrast, brightness, log profiles, colour, saturation, but not sharpening. Any changes you make after it has been encoded will result in visible noise, the greater the change the more visible the noise. With sharpening, it is best to do it as the last stage in the process, before the final encoding.
