The latest firmware = very buggy flights
Mir
Flight distance : 2718491 ft
Is anyone else having issues with the latest firmware? Particularly with Tablets?
Ever since I upgraded to the latest firmware I've been having nothing but issues. Here they are in no particular order:
- Range dramatically reduced: My signal drops out only a mile away. In the same areas with previous firmware, no range problems.
- Tablet randomly shows "Aircraft disconnected"... then reconnects. RC however, doesn't disconnect. Tablet shows poor RC signal, but RC shows good signal. (wtf) This problem did not happen with previous firmware.
- Tears and artifacts across the screen, even at close range. This also did not happen before.
- "Wheel Error" for no reason, when using the gimbal roll. Totallly random, happens once or twice during flight
- RC lost contact with the Mavic for about 20 seconds. This happened once and was not fun at all. - DJI Go 4 app crashes when entering a "warning zone", random
My last flight which was today, ALL of these issues happened in a span of 20 minutes. This is an area I've flown more than 20+ previous flights with zero problem.
I've been pretty positive about my mavic experience in the past, apart from a few hiccups, but this last round of issues has blown my confidence in the aircraft.
2017-1-6
DJI-Ken
Flight distance : 1515312 ft
What device are you using?
I am using a iPad Air2 and Mini3 and have not experienced any issues.You may also want to try syncing your flight records, then delete/reinstall DJI GO4.
2017-1-6
Mir
DJI-Ken Posted at 2017-1-6 15:09
Hey Ken, I'm using the Nvidia Shield K1 Tablet.
So far I've reinstalled DJI Go 4 which didn't help. Also reformatted the Shield with a clean version of Android, also didn't help.
2017-1-6
DJI-Ken
Mir Posted at 2017-1-6 15:58
That's strange, when you say the range is reduced is that RC control or video.
You can lower the transmission bitrate in HD settings and also use a custom channel.
I wish I had a Should K to test.
2017-1-6
Mir
I think the next step for me would be to test the regular DJI Go App. Based on the reviews of DJI Go 4, I don't seem to be the only one having the same issue. At the moment Go 4 is getting trashed with bad reviews with most people complaining of crashes and disconnects... while the basic GO app has a healthy 3.9 rating.
Android doesn't seem to be a likeable platform for dji software engineers :-/
2017-1-6
fanseb85c303
Use DJI go 3.0.1. Still have Google maps and works great
2017-1-7
DJI-Ken
Mir Posted at 2017-1-6 19:43
I have not experienced any issues with GO4, but I don't have any Android devices.
2017-1-7
Mir
I gave up today and bought an iPad mini 2. Returning the Shield tablet
2017-1-7
Mir
I just had the same problem on the ipad. After further inspection it seems the bottom USB port of the Mavic RC is unstable. The slightest movement of the cable and the tablet disconnects, causing most of the issues above. I probably plugged/unplugged this port 5-6 times, and no rough use.. is it a design flaw or something?
2017-1-7
