Fast flashing yellow light and connecting.Will not bind.After crash.
2392 10 2017-1-7
NorthernLife
So I was using the Active track function following my truck and all of sudden it lost the subject and passed my truck looking at it sides ways and then straight backwards into some bushes. No damage other than one crack in one of the blades, everything still connected and camera still working. I turned it off and went home and then tried to turn it on and do a little test flight around the house. Turned it on connected the app and nothing but "connecting" on the remote controller and a fast flashing yellow light. I tried binding it on the app and then just the RC still nothing. The little light bellow the bind does not light up either. Does anyone have any suggestions?
2017-1-7
Sorry for your crash,NorthernLife. If the controller still cannot link with the RC with aircraft, I'd suggest you to send it in for further evaluation.
Please send an e-mail to support@dji.com with the following info, the subject should be " Forum support". We'll help you create a case.
Case illustration:
Country:
Full name:
Email address:
Phone number:
Shipping Address:
Zip Code:
Forum link for your case:
2017-1-7
Skynet1212
Brazil
I am having this problem too. The mavic do not connect via RC or wifi (as fact the wifi of the mavic do not show in avalible SSID. Some Body can help us?
2017-1-7
GRUMPY69
Flight distance : 13711 ft
im having the same problem.....HELP
2017-1-7
GRUMPY69
i kept my finger on the power button on the drone for 10 seconds and quick release and then pressed again for 10 seconds,done this a couple of times but mine started to work again,
2017-1-8
NorthernLife
Grumpy69,
When you were doing that function the drone was on and it was just a single press and not a double press?
2017-1-8
NorthernLife
And  were you binding it while you did it or after?
2017-1-8
Skynet1212
Brazil
I did this procedure and nothing happen. It´s still not conect RC or Wifi. And the light from the sd card is red.
2017-1-8
WebCo
Flight distance : 137362 ft
Not sure if this might be your issue... but I had to re-link the controller with the drone after getting it back from DJI after a repair.
See Page 36 of the Mavic Pro User Manual
2017-1-8
Skynet1212
Brazil
I tryed to re-link the RC, with no success, and even the wifi not working any more. Tryed connecting via Assitant 2 and no success too. I had fly many 30 times before this issue happen. The drone simple stop to connect with RC, wifi and PC.
2017-1-9
mz-in-norcal
Flight distance : 1005049 ft
Anyone find a way to get around this? I can't rebind, and the Magic Pro just blinks fast yellow.
2018-6-4
