Aardvark
Flight distance : 384432 ft
You got me thinking, so I tried a little experiment here. Powered up my Phantom 4 indoors (All firmware/software at latest versions). Made sure there was sufficient light, being indoors it showed no GPS, and 'OPTI' mode was operating. I then stood just inside the open front door until it started registering satellites, now I stood there for quite a few minutes, 6,7,9,10 satellites, and still in 'OPTI' mode. Only when it reached 11 did it change from 'OPTI' to GPS mode after a few seconds.
Now, I do not fly indoors myself, primarily because there is not enough room. Secondly because to me it is a camera platform and there's nothing really indoors that I would need a flying camera for.
Based on my little test I would be confident that if you were indoors, say in a big games hall or similar, then the OPTI mode would do a good job as long as there is enough light. If you flew past the window and picked up a handful of satellites then I think OPTI would still be fully operational. If you hovered in front of that window and were receiving 11+ satellites then I believe it would switch to GPS mode. At that point the likelihood of getting a rogue GPS signal I think would be very small, probably more chance of an ESC, motor, prop' failure.
Best thing would be to try it yourself indoors beside a window, powered up, motors not armed, and check the mode shown on DJI Go. If it stays on OPTI, then OPTI (VPS) it is. |
