Stupid question about Props
711 3 2017-1-8
Birdog
Flight distance : 664521 ft
Pretty sure I already know the answer, but am just checking.
Do the Propellers have a max number of flights ? (replace after x number of flights) or is it only if they are damaged in some way ?
I bought extra propellers just incase but I`m still using the first set it arrived with, and am noticing a change in the noise they generate while flying, it isnt a bad noise, its just changed.
I guess its probably just the different conditions in the air but am just checking.
Cheers
2017-1-8
gibbd
Flight distance : 18980 ft
As far as i know and have read, you probably only need to replace if damaged.  Thats just my thought, probably worth a response from the very knowledgable @DJI KEN or other DJI staff member on the forum with regards to this though.
2017-1-8
hallmark007
Flight distance : 9827923 ft
If they show any damage bin them, but other than that you can use them as long as you like, some people like to change them after a period of time and that's ok to, in the scheme of things they are inexpensive.  Good luck.
2017-1-8
We recommend that they are changed around 200 flights.
If the propellers are scratched or damaged, please replace it.
2017-1-9
