Drone Deploy
2298 8 2017-1-11
Nole4life80
Flight distance : 298737 ft
Has anyone else used Drone Deploy?
It is an awesome app/website that automatically maps an area. Just set the parameters and it does everything on its own. You then can upload the pics and it will create a 3D map!
The problem seems to be the "tap to focus".
Has anyone else solved this problem with Drone Deploy?
2017-1-11
karaemurphy23
Flight distance : 9140 ft
For "tap to focus," I assume you're using a Mavic?
2017-1-11
Ex Machina
Flight distance : 1806362 ft
The service does seem pretty cool, especially the 3D mapping component: https://www.dronedeploy.com -- might give this a shot once I've mastered teh DJI Go 4 app -- thanks for sharing this!
2017-1-11
thehippoz
Flight distance : 23 ft
You could try in android 6. Launch litchi and fly, focus on ground, adjust gimbal horizon with c2 + exposure dial, land.
Turn off rc and close litchi. Turn rc back on and select drone deploy. It should be in the list if installed. I don't have it but sounds interesting.
2017-1-11
Nole4life80
No other drone app can be running while drone deploy is and while it is flying the mission you can no tap to focus. You can only sit back and watch.
2017-1-11
Nole4life80
karaemurphy23 Posted at 2017-1-11 10:08
yes I am
2017-1-11
thehippoz
Nole4life80 Posted at 2017-1-11 12:00
Yeah, but if you read, I'm sure that would work.
2017-1-11
Albatross911
Flight distance : 1708084 ft
Per their app description they don't support the Mavic yet, perhaps better wait for their update to officially support it?
2017-1-11
Nole4life80
They must have changed the description because I contacted them before downloading the app.
2017-1-19
