Phantom 4 battery hub for battery update?
954 4 2017-1-11
swk
can someone tell me if the dji battery hub can be used to update batteries and does it need to be done thru assistant 2 ?
2017-1-11
Cetacean
Flight distance : 2528264 ft
Aloha swk,
     Unless DJI came out with something new, the battery has to be in the aircraft in order for a battery update to take place.  In my case, I have noticed the advisory at the white start-up screen before the camera view is enabled.  I touch the notice and the update takes maybe a minute, done.  Real easy.  Otherwise, you can use the Assistant 2 and swap out the battery with repeated restarts and unplugs, a bit humbug for me, but it works to.
     Hope this helps!
Aloha and Drone On!
2017-1-11
swk
Thanks but what is the mini USB used for
2017-1-11
Indio
Flight distance : 303373 ft
Austria
swk Posted at 2017-1-11 16:14
is for update the hub if necessarily
2017-1-11
swk
Ok thanks for the help will update in AC
2017-1-11
