TX Stopped charging
595 9 2017-1-11
floridajustin
Why would my new TX stop charging? I believe it may have beeped a few times (was in the other room) and when I checked on it, there were no charging indicator lights. I unplugged and plugged in again and it began charging like normal.
2017-1-11
floridajustin
As a follow it, it continues to charge for 15 mintues or so and will stop charging. I then have to unplug and repeat again to get the indicator lights to show it's charging. Perhaps it's still charging even though the lights aren't flashing?
2017-1-11
Kirk2579
Flight distance : 37415 ft
floridajustin Posted at 2017-1-11 16:11
might it be fully charged at this point?
2017-1-11
floridajustin
Kirk2579 Posted at 2017-1-11 16:15
Nope...it was at 65% when I took it for a maiden flight. It continues to charge but its finicky. It charged for 10 minutes a while ago, now it only did it for a minute. I'm checking now to see if it's charging even though the lights are showing.
2017-1-11
floridajustin
Update, the TX is actually charging even though I'm not seeing any flashing lights. Is this normal?
2017-1-11
Kirk2579
floridajustin Posted at 2017-1-11 17:25
Push the charger plug into the RC harder
It may not be inserted completely.
Mine will hesitate/stop at a point, but then I have to push past that point with a bit of effort
good luck and have fun flying
2017-1-11
Phantomski
Flight distance : 14869882 ft
agreed, the plug is a bit stubborn... which model r we talking?
I assume it's in off state while charging?
2017-1-11
floridajustin
Yes, the TX is off, the plug is pushed well into the TX. It's funny, sometimes it'll light up the TX for a couple of minutes, other times it shuts off after a minute of charging. Not sure what's going on. The battery will continue to charge though.
2017-1-11
P4P+
floridajustin Posted at 2017-1-11 18:40
I am probably stating the obvious, but you are charging the rc and the battery separatley right? I made the mistake of putting them both on the charger at the same time and when the battery finished charging the transmitter lights went out. I disconnected and reconnected the transmitter and the lights then blinked until fully charged. The transmitter battery takes much longer to charge than the AC battery.
2017-1-11
P4P+
P4P+ Posted at 2017-1-11 18:49
Also to note, the charger has to be plugged into the wall first, and then connect the aircraft battery or remote control. My first time charging I did the opposite and the battery lights blinked for 40 minutes without charging or without the charger getting warm.
2017-1-11
