Osmo handle - Z 3 compatible?
1653 13 2017-1-12
Andy LIS
Flight distance : 3358875 ft
Hi folks,
Is the Zenmuse Z3 gimbal (as used with an Inspire) compatible with an Osmo Handle?  Like how the X3 gimbal can be mounted on there?
Cheers
Andy
2017-1-12
Barney2k
No it doesn't look like the Z3 is compatible with the Osmo handle.
See point 2 of the FAQ's on the Z3 page:
2. Does the DJI Osmo support the Zenmuse Z3?
No. The Zenmuse Z3 is specially designed for aerial photography and is not compatible with the Osmo.
The X3 Zoom is though (the camera that comes with the Osmo+). Just depends how much zoom you need I guess!
2017-1-12
BIGDZ
Flight distance : 10255860 ft
Barney2k Posted at 2017-1-12 07:29
The Z3 does work with the Osmo(NOW), if you have the most recent Fw update. https://dl.djicdn.com/downloads/ ... ase+Note_201611.pdf
2017-1-12
BIGDZ
It does!!!!! It works on my I1 and osmo
2017-1-12
Andy LIS
Ace.  Anyone know if it (the Z3) is focusable, or is it a fixed focus camera like the x3?
Thanks!
2017-1-12
BIGDZ
Andy LIS Posted at 2017-1-12 13:32
Thanks!
Tap to focus like the MP, P4P and I2. You can enable autofocus or manual...
2017-1-12
Barney2k
Wow I never knew that BIGDZ!
News to me...
That's very useful - thanks for the heads up!
2017-1-13
TontonAlainG
Flight distance : 4537 ft
BIGDZ Posted at 2017-1-12 10:02
The Z3 does work with the Osmo(NOW), if you have the most recent Fw update. https://dl.djicdn.com/downloads/zenmuse_z3/Zenmuse+Z3+Release+Note_201611.pdf
I confirm, the Z3 is compatible with the OSMO (after upgrades). One point nevertheless, no sound recording (no mike on the Z3) but even with an externel mike plugged on the handle (which show on the GO App screen), no sound recording. Maybe a further upgrade ?
2017-1-13
TontonAlainG
TontonAlainG Posted at 2017-1-13 07:30
The Z3 is also compatible with the extension cable on the OSMO
2017-1-13
TontonAlainG
Even more fun, the Z3 on standard OSMO allows for moving timelapse that is not avilable with the original camera.
2017-1-13
BIGDZ
TontonAlainG Posted at 2017-1-13 08:08
didn't know that it can move when doing TL...sure its not gimbal drift?
2017-1-13
TontonAlainG
BIGDZ Posted at 2017-1-13 21:08
When the Z3 is on the OSMO, and you go in timelapse menu, you have the possibility to select on the second page of the menu the beginning position of the gimbal, several intermediate positions, and the final position, and when you start the timelapse, it will smoothly go through the various angles you have set.This is not available with the X3.
2017-1-14
BIGDZ
TontonAlainG Posted at 2017-1-14 00:51
Good to know, however TL on the Osmo is not of good quality. It's probably best to do it on another camera.
2017-1-14
TontonAlainG
BIGDZ Posted at 2017-1-14 07:25
The video file produced by the OSMO is only in 720p, but you can record both video + jpg's, and produce a 4K TL from the jpg's, which is highly acceptable.
2017-1-14
