Mike-the-cat
Flight distance : 22488593 ft
Singapore
DaveDotNet Posted at 2017-1-14 07:39
Ah ha.. Thanks for the clues.. Yes, indeed, it's the red prop. Only on this one motor, the prop rattles when I move it round by hand (still haven't started it up). It's also loose in some sense whereas the others are rock solid. I've tried different red props with the same outcome, although the props are ok on the other red motor.Will look at the other threads shortly for the workaround...
Aside from the noise.. is this a safety issue ?
I have posted on this matter too. Its either the prop locking mechanism asymmetrically tightened or some issue with prop manufacturing tolerance. For the latter, try the spare props provided. otherwise, unlock and re-tighten the locking mechanism. The issue is not fatal to flight but it might increase wear over a long time |
