Confused re. Compass
454 6 2017-1-13
DAF99
Flight distance : 14423 ft
New owner of a Phantom 4 Pro+ here busy trying to digest the manuals and instructional videos. I'm confused about the compass. In the YouTube videos for Phantom 4 it says to set compass before every flight. In the Phantom 4 + User Manual it says don't reset unless advised by the controller software.  Is there a difference between Phantom4 and Phantom4+ in this regard or am I missing something?
Thanks.
2017-1-13
Labroides
Flight distance : 9991457 ft
It's unclear whether there is a physical difference or DJI just updated the badly worded manual.
The youtubers you mention don't know what they are talking about.
It was never a good idea to recalibrate the Phantom each flight.
You will be better off not messing with compass calibration.
As the manual says, don't touch it.
I have more than 60 flights on the new bird for a distance of 220km without a single calibration of anything and it's performing perfectly.
2017-1-13
DAF99
Thank you Labroides. I will proceed based on your advice. Just to be clear, the 'YouTubers' in this case was an official DJI Instructional video for the Phantom 4.
2017-1-13
Labroides
DAF99 Posted at 2017-1-13 16:28
That's not surprising.
The DJI manual section on compass calibration was always confused and the troops were just following the company line.
2017-1-13
P4P+
I have not calibrated anything when I got my P4P+ a few weeks ago. After about a week when I was running some tests, the controller issued a calibrate compass message and I did so at that time. I have not done any other calibrations since then. Also I believe that I got that compass message because I had left two magnetized files out and I put my Phantom down pretty close to them.
2017-1-13
Labroides
P4P+ Posted at 2017-1-13 16:54
"the controller issued a calibrate compass message"
The manual still isn't perfect.
If you get a compass error message the first thing to do is look at where your Phantom is.
If the compass error is because you put the Phantom down on a car roof, manhole cover, reinforced concrete etc, you do not want to recalibrate there.
Simply moving away from the magnetic interference should be all that's needed.
2017-1-13
Phantom-Paul 7
Flight distance : 2551634 ft
I Second what Labroides said,  Once you have a good calibration leave it alone until the Go App says otherwise.
More damage is done by doing unnecessary compass calibrations than just about anything else. (except perhaps unnecessary FW updates     )
I have  137 flights on my 2 phantoms  and only calibrate after a major change to the birds,    I go out to a nice vacant grassy field with nothing about , make sure I take off my watch  and leave car keys ,phone etc, behind and perform the calibration there . Check the readings in the sensor menu and if good then I leave it alone no matter where I fly .   If I get a compass error when setting up I'll look around for the cause and move if necessary instead of fiddling with a good compass.
2017-1-13
