P4 and a new ipad mini 2
792 13 2017-1-15
freelanderuk
Flight distance : 177720 ft
Just got a ipad mini 2 wifi and 4G to use with my P4, i have installed the Dji go 4 app , I have never used apple products before only Android,  are there any settings on the ipad mini or DJI App  I should alter to enable them to work at optimum performance
Cheers
2017-1-15
Capoeira82
Flight distance : 53356 ft
I have this configuration too P4 + iPad Mini 2, it works like a charm
2017-1-15
Chief RM
Flight distance : 136204 ft
I use a iPad mini 2 and did not change any settings and it works great with my P4
2017-1-15
freelanderuk
Thanks , I have a nexus 7 2013 also but the ipad seam a little smoother
2017-1-15
Grrrrrr
Flight distance : 1073025 ft
I am using the iPad Pro 12.9" and only thing I had to change was the Metric to imperial settings and works like a charm. I bought one of the extenders for the remote to be able to use the 12.9 inch iPad just barely fits in
2017-1-15
fansae7a0ce6
Flight distance : 4754 ft
I use the ipad mini 2 wifi+4G and I also use the ipad pro 9.7 wifi+4G both on Tmobile with my Phantom 3 and Phantom 4 with no problems.
2017-1-16
JohnnieYaz
Flight distance : 4357323 ft
same set up I used.. works perfect!
2017-1-16
Cedric Pieterse
Flight distance : 1225827 ft
Sweden
Same here, it works well, no issues
2017-1-17
Chriscycling
Switch off the background app refresh on your iPad is a well known tip
2017-1-17
freelanderuk
Chriscycling Posted at 2017-1-17 13:28
Thanks for the tip,
There more I use the app on the ipad mini 2  the smoother it seams compared to the Nexus 7 2013,  I have also installed the GS Pro app and that  runs smooth also, hoping to get out at the weekend and give the bird a fly and put the tablet threw it's  paces
2017-1-17
DJI-Jamie
Flight distance : 112405 ft
freelanderuk Posted at 2017-1-17 23:27
Thanks for the tip,
Good to hear you're liking everything thus far. As others mentioned, the iPad Mini 2 does not need much in the ways of tweaking.
2017-1-17
Jester
Flight distance : 195016 ft
It's pretty much plug and play
2017-1-18
Visalia Califor
You will quickly learn why apple is the top dog. The other guys like to tout the hardware but the hardware is nothing without good software and Apple's is by far the best.
2017-1-18
Karlos7
Flight distance : 586873 ft
What is the reason for this? Just curious.
2017-1-18
