Capture Date incorrect
1892 27 2017-1-15
fans1ee34a72
Flight distance : 1263317 ft
Took out my new P4P today and was very impressed with the handling.  It felt much more stable than my P3P.  However, once I loaded the footage from the day onto the computer all the videos showed a "Capture Date" of 1951 instead of 2017.  The date on the iPad I use for controlling is correct.  The Capture Time for the still photos I took are correct, however, any video files are showing the incorrect date.  It appears to be a bug in the DJI Go 4 App.  Anyone else experienced this here (there's quite a few that have when I Google.)?
2017-1-15
DJI Natalia
Super Moderator
Flight distance : 318 ft
May I know what SD card you are using? If you use the original SD card coming together with aircraft, the capture date should be correct.
If you use other SD cards, please make sure firmware for AC and RC is up to date, then check again.
2017-1-15
fans1ee34a72
DJI Natalia Posted at 2017-1-15 20:14
Before I flew it for the first time I updated to the very latest firmware using the DJI Assistant software on my Mac.  I also upgraded the controller firmware via the DJI Go 4 App.  The SD card I used was the one that came with the P4P.  I did NOT format the card before I flew.
2017-1-15
DJI Natalia
Super Moderator
fans1ee34a72 Posted at 2017-1-15 21:44
Please upload a screenshot of the firmware version here and help confirm the capacity of SD card, thanks.
2017-1-15
richparry
Flight distance : 724767 ft
DJI Natalia Posted at 2017-1-15 22:09
Natalia,
Many people on this forum have mentioned the problem with the YEAR being incorrect for a video file. In 2016 the P4P video files were time stamped with 1950, now in the new year 2017, the video files are time stamped with 1951.
You MUST load the file into a professional video editing program that shows the full Meta Data. I have attached an example of a video I shot yesterday. The meta data is incorrect for the YEAR. The month, day, and time are correct. The YEAR is wrong.
This has nothing to do with SD cards. I'm using a P4P+ that is completely up to date, you have told me yourself in a separate message to me on another thread.
Rich
2017-1-15
DJI Natalia
Super Moderator
richparry Posted at 2017-1-15 22:34
Natalia,
I've reported this case to our engineers and they've checked it, and the problem should be fixed after firmware upgrading.
If problem persists, I need collect more details, then transfer your feedback again to our engineers to locate the problem.
Thanks for your support!
2017-1-15
fans90522c06
Belgium
Natalia,
I confirm the same problem occurs for me with the PH4PRO +
Regards
Marc
2017-1-16
JAFARINI
Flight distance : 8449341 ft
Georgia
Natalia for me it is same. For both Stock SD and for Sandisk SD card Videos have wrong date.
2017-1-16
DJI Natalia
Super Moderator
fans90522c06 Posted at 2017-1-16 01:39
Regards
Everything is up to date, right?
What is the capacity of the SD card you're using?
2017-1-16
DJI Natalia
Super Moderator
JAFARINI Posted at 2017-1-16 01:58
You've upgraded the firmware, right? please help confirm the capacity of the SD card, I will report it to our engineers again.
2017-1-16
JAFARINI
Georgia
DJI Natalia Posted at 2017-1-16 02:37
Yes I did Firmware upgrade several days ago on Aircraft. SD I am using is one Panasonic that comes with drone and another is Sandisk Extreme Pro 32GB.
As I said for Photos it seems correct but videos in 2016 it was reading as from 1950 and now it imports as 1951.
2017-1-16
fivetonine
Flight distance : 985135 ft
Austria
I haven't had this issue with any of my Phantoms, but with OSMO. But for me, the wrong date is usually 2013.
2017-1-16
fans90522c06
Belgium
Data for photos is OK. Only the videos and I use the sd card coming with my PH4PRO+ !!
Regards
Marc
2017-1-16
fans1ee34a72
Firmware is currently at V01.02.0304.
SD Card is the card the P4P shipped with:
SD Card
SD Card
2017-1-16
fans1ee34a72
fans1ee34a72 Posted at 2017-1-16 14:03
I do want to point out another error.  If you look at my image of firmware, it shows current version at V01.02.0304-  <-- Note the negative sign!  Using the DJI Assistant software I "upgraded" for a second time and now the firmware version shows V01.02.03.04 with NO negative sign.  So in addition to naming the firmware versions with numbers apparently there is a difference between V01.02.0304- and V01.02.03.04
This should be documented somewhere and well just shouldn't happen -- use version numbers to differentiate different versions of software and not a negative sign.
I will now test a video and test it's capture date.
2017-1-16
fans1ee34a72
I am on the very latest Firmware V01.02.0304 and I just took a sample video and again, the Capture Date is in the year 1951.  This is a bug in the firmware!  Time and month and day are correct.  The year is NOT.
Capture Date
Capture Date
2017-1-16
fans1ee34a72
DJI Natalia Posted at 2017-1-15 23:27
It's still a problem and has not been fixed in V01.02.0304 of the firmware.
2017-1-16
Indio
Flight distance : 207280 ft
Austria
for me is working well
sandisk 64GB extreme pro
have not the minus in firmwarenumber
2017-1-16
DJI相机部大帅哥
DJI R&D Squad
China
Dear customer,
Could you tell me the source of file  Geology2016-01ABDSP_04.MP4 ? Is it the original file in the SD? Once the file have been moved from SD to other media, the file create file will be changed also. So please show this detail so as to help us to find the reason. Very thanks.
2017-1-16
DJI相机部大帅哥
DJI R&D Squad
HI fans1ee34a72,
Whether every video and photo date is invalid(1951.XX.XX) or not?
Could you do a capture and then do another capture after 20 seconds. At the same time, please help us to check the create time of these two pictures and verify whether the interval  is correct ?
Thanks a lot.
2017-1-16
fans1ee34a72
DJI相机部大帅哥 Posted at 2017-1-16 19:41
HI fans1ee34a72,
This problem does NOT affect photos.  Photos are fine.  The problem only affects Video files.  I'm using 4k video in the highest resolution 4096 saving as .mov with mp4 encoding and dLog color correction.  Those files when loaded into Adobe Lightroom have a capture date of year 1951.  It affects all video files including those 20 seconds apart.  I took 8 videos on my first flight and each had a capture date of 1951.
2017-1-17
trance728-
Flight distance : 179738 ft
fans1ee34a72 Posted at 2017-1-17 10:25
Could it be something that lightroom is doing to the file on import? I just checked the dates on my videos and photos and all are correct and I have the P4P+ as well. Does it show 1950 for the year if you look at the file on the SD card?
2017-1-17
DJI相机部大帅哥
DJI R&D Squad
HI fans1ee34a72,
Very sorry for your inconvenience, Could you do a screenshot and show us. you can do it as follows step:
1. do a new record;
2. connect you drone to the PC or insert your SD card to the card reader ;
3. get the file attributes and show us the screenshot for the file attributes;
Thanks a lot.
2017-1-19
richparry
Tip: The post by the administrator or moderators shield
2017-1-19
richparry
fans1ee34a72 Posted at 2017-1-16 14:18
[view_image]
Fans ...
What tool did you use to capture the 1951 metadata. I used Adobe Bridge. We both agree there is a problem, I'm just curious what tool you used.
Rich
2017-1-19
ChrisDO
Hello, there is the same problem on my Mavic. Date 1951.
2017-2-21
kikap
Flight distance : 18012 ft
https://forum.dji.com/thread-84525-1-1.html
DJI R&D please look into it. Should be dead simple to fix.
2017-3-12
fansb70b5cb2
Flight distance : 354081 ft
kikap Posted at 2017-3-12 22:30
I'm having the same issues with the video files only, showing 1951 as date created.  I'm using DJI Go 4, on an ipad mini 2, and I use Adobe Bridge CS6 on my mac, running Sierra to view the metadata.  The AC FW is 01.02.0304.  I have tried the original SD card, as well as some Lexar 32GB cards.  If I view the date created in finder, it's correct.  Might be a bug in Adobe?
2017-4-30
