Top Ten Common Mistakes Phantom Pilots Make
12
39300 69 2017-1-16
Midwest_Blue
Flight distance : 202247 ft
Very well put together information. Thank You. Wish I've found this info before I flew. But still flying after 15 hours, with only  broken props.
2017-2-7
jeffinhizhands
Thank you for trying to help. I for one appreciate the info....
2017-2-9
Ujjawal Animato
Flight distance : 6711102 ft
India
Thanks for your share
2017-2-9
fans6fb22703
I just got my phantom 4 and I'm having video issues during flight and playback any thoughts?
Please advise
2017-2-10
Defiant_Child
Flight distance : 105010 ft
tokenbrit Posted at 2017-1-16 15:03
"If you haven’t used a set of propellers for more than 50 flights, but they’re over a year old, still change them, as the threads will degrade over time from exposure to air."
Air does not deteriorate plastic, rather mousture and other contaminants can cause "hydrolysis", a chemical process that causes certain chemical bonds to break or "unzip" leading to their deterioration. In addition, UV light (from the sun's rays) also contributed to polymeric deterioration. To the extent that props are molded using thermoplastic alloys (as opposed to thermoset resins) exposure to heat may cause warpage.
I haven't studied how props are molded nor what polymers or alloys are used, but a good rule of thumb is if you know that plastic parts are prone to deteriorate in the presence of moisture, UV, or heat, is to store those parts in a cool, dark, and dry place when not in use. Keep fresh desiccant (moisture scavenging) bags with the items you store and wish to protect.
Since I'm new to the forum (but not to polymers) and this is my first post, I am happy to defer to the greater and sage wisdom of others (except about reading manuals. I never read manuals.)
Cheers!
2017-2-12
blackcrusader
Flight distance : 689774 ft
Taiwan
Mike-the-cat Posted at 2017-2-6 16:42
Very good points but have you ever tried to write an instruction manual for a kid with a short attention span?
That describes many newbie flyers and customers.
ROFL made my day
2017-2-12
tokenbrit
Flight distance : 384094 ft
Defiant_Child Posted at 2017-2-12 01:42
Thanks - you obviously know your topic
2017-2-12
liningiv
Flight distance : 329409 ft
P4 no thread on props.
Therefore not applicable.
All P4 and P4Ps have mechanical locking.
2017-2-15
#shotxclvck
Flight distance : 3423297 ft
THANK YOU FOR POSTING.
2017-2-15
phil0
Well I never even thought of changing the propellers unless they're damaged. Good to know. Thanks.
2017-2-16
ROYALNAVPTI4
Flight distance : 184646 ft
Great tips, excellent! I too was unsure about the RTH function, i have not tried it yet as always have LOS, safety first!
2017-2-16
Woodwanger
I also didn't know about the RTH 20mtr rule .....good to know as this could really catch a noob like me out :-)
2017-2-19
leonardrosser
Indonesia
nice tips to be known!
2017-2-22
SkyMemories
Flight distance : 139967 ft
Malaysia
Good sharing. tq.
2017-2-23
Johnnyv
Flight distance : 2798707 ft
trance728- Posted at 2017-1-16 23:21
Sounds like a ploy to get you to buy more propellers.
If they are subject to air degradation, why are they not sealed when new? How are you supposed to know how old a set of propellers you purchased even are? It's not like they have dates printed on them.
DJI propellers are sealed when they are new.
2017-2-23
Kilted Flyer (D
Flight distance : 1096637 ft
SkyerUAS Posted at 2017-1-28 07:34
Quote -"We suggest changing propellers every 50 flights, and a set of propellers should not be used for more than 100 flights. If you haven’t used a set of propellers for more than 50 flights, but they’re over a year old, still change them, as the threads will degrade over time from exposure to air."-
I'd like to understand why the recomended prop replacement interval is based on flights instead of flight time. If the concern is the cumulative stress fatigue on the props, the wear rate would be paced  by the duration and intensity of the stress, which are linked to flight times and types of flight profiles/maneuvers (i.e. aggressive flying/braking vs. hovering or  smooth movements). Recognizing that operating conditions are many and varied, I suppose DJI may be using the average air  time per flight they see from the telemetry data that the DJI GO app collects, but given that it also records flight time, it seems it would be more appropriate to have a recommended interval based on flight time, with a plus/minus range based on mission profiles.
The only issue i see with props is they only "wear out" when being installed and removed after each flight. The threads get worn since were talking about plastic against a metal motor stud. Over time I can see the threads getting worn.
2017-2-25
SkyerUAS
Flight distance : 1754019 ft
Kilted Flyer (D Posted at 2017-2-25 13:23
A valid point
SKYER
“Fly your drone as though you were flying in it yourself…”
See aerial short films at my YouTube Channel: https://www.youtube.com/channel/UC304REG4t2_OWJmQDHLvQ2w
2017-2-25
TheDennisWagner
Flight distance : 136273 ft
Well written. Thanks for sharing.
2017-2-27
blackcrusader
Taiwan
phil0 Posted at 2017-2-16 05:50
I've done over 130 flights on the same props and they are as good as new.
Then again I don't use them to chop grass or leaves off trees.
I also do not remove them from my drone.
2017-2-28
TPVAerials
All good points.
Will be saving this to brush up on down the road as an easy reminder!
2017-3-2
chillpilot1
Thank you for the advices, very helpful. I am newbe so I want to know as much as possible to fly safely.
2017-3-4
Ujjawal Animato
India
Thanks
2017-3-7
tokenbrit
Hello Mindy - what's the logic behind making the drone land where it is when RTH Is pressed  within 20 meters of the home point please? Why not just make it return to the home point? I have never understood this.
2017-3-7
RichJ53
Flight distance : 1837356 ft
Very nice summary of problem situations and thank you for sharing.
A good preflight check list and some common sense will take care of most of these.
Rich
2017-3-8
FCjosh
Number 8 helps. Thanks1
2017-3-12
fans58fdb581
Good info, thanks!
2017-3-13
DronePanora
Flight distance : 599685 ft
This is a great outline.
2017-3-14
fans18aa1ddd
Flight distance : 1063389 ft
tokenbrit Posted at 2017-3-7 04:51
It's probably a safety issue. DJI does not want the DJI firmware to take over flight if it's already that close to the take off point. I'd think they know usually the operator is close to that point. So it does not take over at all. However, once it's further away, it has no choice but to take over and fly back to the home point.
2017-3-30
AlansDronePics
Flight distance : 814751 ft
Guernsey
R&L Aerial  Posted at 2017-1-26 10:29
#8 would not be an issue if DJI would leave your RTH altitude alone when upgrading the app. I have RTH set at 50 meter because trees in my area are 30 meters tall. Every time I update the app it resets RTH altitude back to 30 meters and gives you no notification that RTH altitude has been reset.
They warn you the settings generally may change, so it is your responsibility to check.
2018-4-11
master chief
Flight distance : 116634 ft
Thanks; as a beginner, I need this.
2018-12-31
12
