Cmartin3977
Flight distance : 304744 ft
I noticed some abnormal landing gear issues while flying recently. I have it set for auto landing gear and raising works just fine but hasn't wanted to lower until maybe 2 foot from the ground which seemed to be too late in my opinion, but I dealt with it and was careful when I came in for landing. It has worked that way up until the last two flights. Then I started having issues. I was doing slow flight with it and at about 60ft high and all of the sudden the landing gear lowered, all on its own, no warnings, just a notice saying landing gear lowering thru the app. I have no idea why. I manually toggled the gear up and it went up no problem. Then as soon as I wanted to land , the landing gear would not come down on automatically. I had it hovering about 8" from the camera touching the ground and it won't come down. I had to toggle the gear lever and then the gear came down, via the lever, not automatically. This behavior is on the latest app version, one update back on the transmitter, and two updates back on the inspire1. Then last night I decided to bring everything up to date firmware wise, and now I cannot get it to respond to travel mode via the transmitter. I do the 4 lever actions, and it now gives me a blue light and says transmission signal error on the app. I can do the 4 lever actions again and it will come out of the blue light and back to normal. I can go into travel mode via the app no problem. I cannot verify if the update has helped the gear issues while flying as I haven't had a chance to test. Can anyone maybe shed some light into what the heck is going on? Thank you!! |
