Aardvark
Flight distance : 384432 ft
Yes, yes & yes.
Try rolling the RC back to V1.6.....I suspect you just upgraded it to V1.8. This appears to cause problems especially for the Android community.
Try this:-
Connect display device (with wifi connection) to RC and power both up (aircraft should be off).
Run DJI Go, on initial screen (where it displays aircraft type etc) at top right hand corner you will see a 'graduation hat' icon (or three lines if Android). Hold your finger on that for about 5 seconds and release. You should now see a black screen appear with an option to roll back RC firmware. Make sure RC is well charged, takes about 5 minutes or so. Power down when complete. Restart all and check all working, you may need to relink RC to aircraft. |
